Partial Least SquaresMethod Table |
Minitab displays information about the method used to analyze the PLS model. The output depends on which method you choose to select the components and on whether you use cross-validation.
If you do not use cross-validation, Minitab displays:
If you use cross-validation, Minitab displays:
If categorical predictors are in the model, the method table specifies the type of coding used.
The components selected by Minitab form the model that is used in the PLS analyses and plots.
Method
Cross-validation Leave-one-out Components to evaluate Set Number of components evaluated 10 Number of components selected 10 |
In this example, the scientists chose to use cross-validation, leaving out one observation at a time. They did not specify the maximum number of components to validate. The output shows that:
