Attribute Agreement Analysis - Options
Stat > Quality Tools > Attribute Agreement Analysis  > Options
Use to display Cohen's kappa and the disagreement table. Also, you may specify a value for the confidence level.
Calculate Cohen's kappa if appropriate: Check to calculate Cohen's kappa when appropriate. Minitab will calculate Cohen's kappa when two appraisers rate a single trial or when each appraiser rates two trials.
Display disagreement table: Check to display the disagreement table. Minitab displays how often each appraiser's assessments differ from each known standard or attribute value. You must specify a column for Known standard/attribute in the main dialog to enable this checkbox.
Confidence level: Enter the confidence level of the interval estimation of the percentages of the assessment agreement within appraisers and between each appraiser and standard. The default is set at 95.
