Data - Attribute Agreement Analysis
Data can be text or numeric. The assigned ratings can be nominal or ordinal:
·    Nominal data are categorical variables that have two or more levels with no natural ordering. For example, the levels in a food tasting study may include crunchy, mushy, and crispy.
·    Ordinal data are categorical variables that have three or more levels with a natural ordering, such as strongly disagree, disagree, neutral, agree, and strongly agree.
If the response is a text column and the data are ordinal, use Editor > Column > Value Order to define a nonalphabetical ordering on the text values.
Data can be stacked in an attribute column or unstacked in multiple columns. For attribute column data, stack all of the responses in one column and set up grouping indicator columns for the appraiser and part number. The grouping indicators define each sample. Grouping indicators and responses can be text or numeric. For multiple column data, responses for each appraiser and each trial are in separate columns.
Here is the same data set structured both ways:
Attribute column data
Sample
Appraiser
Response
A
Good
A
Good
B
Bad
B
Good
A
Good
A
Good
B
Good
B
Good
A
Bad
A
Good
B
Bad
B
Bad
A
Good
A
Good
B
Good
B
Good
A
Bad
A
Bad
B
Good
B
Bad
Multiple columns data
Sample
Appraiser A - Trial 1
Appraiser A - Trial 2
Appraiser B - Trial 1
Appraiser B -Trial 2
Good
Good
Bad
Good
Good
Good
Good
Good
Bad
Good
Bad
Bad
Good
Good
Good
Good
Bad
Bad
Good
Bad
Note
When your data are in multiple columns, you must enter the trials for each operator together, as shown above. The order of the trials must be the same for each operator.
