Stat > Quality Control > Capability Analysis > Binomial > Tests
With Capability Analysis (Binomial), you can perform the four tests for special causes. Each test, as shown in the table below, detects a specific pattern in the plotted data. The occurrence of a pattern suggests a special cause for the variation that should be further investigated.
You can set preferences for the tests to perform and for the sensitivity of these tests using Tools > Options > Control Charts and Quality Tools > Tests.
When a point fails a test, it is marked with the test number on the plot. If a point fails more than one test, the number of the first test you request is the number printed on the plot. Minitab prints a summary table in the Session window with the complete information.
Test 1 One point more than 3 sigmas from center line |
Test 2 Nine points in a row on same side of center line |
Test 3 Six points in a row, all increasing or decreasing |
Test 4 Fourteen points in a row, alternating up and down |
Tests For Special Causes
Perform all four tests: Choose to perform all four tests shown below.
Choose specific tests to perform: Choose to specify a subset of the four tests, then check any combination of the tests listed below.
Six points in a row, all increasing or all decreasing
