Stat > Quality Tools > Capability Analysis > Normal > Estimate
Controls number of observations used in estimating standard deviation.
You can set preferences for the estimation of s using Tools > Options > Control Charts and Quality Tools > Estimating Sigma.
If you select the Johnson transformation, these estimation options are ignored because Minitab is unable to estimate the within subgroup variation. |
Methods of estimating standard deviation
(for subgroup size > 1):
Rbar: Choose to estimate standard deviation using the average of the subgroup ranges.
Sbar: Choose to estimate standard deviation using the average of the subgroup standard deviations.
Pooled standard deviation: Choose to estimate standard deviation using a pooled standard deviation.
Use unbiasing constants: Uncheck to estimate within-subgroup standard deviation not using unbiasing constants. The default is to use the unbiasing constants.
(for subgroup size = 1): Minitab generally estimates standard deviation using the sample standard deviations or ranges of each subgroup. But when the subgroup size is 1 you cannot calculate sample standard deviations or ranges. Minitab estimates standard deviation using moving ranges instead.
Average moving range: Choose to estimate standard deviation using the average of the moving range.
Median moving range: Choose to estimate standard deviation using the median of the moving range.
Square root of MSSD: Choose to estimate standard deviation using the mean squared successive differences.
Use moving range of length: Choose to enter the number of observations used to calculate the moving range. By default, a span of 2 is used as consecutive values have the greatest chance of being alike. The span must be < 100.
Use unbiasing constants to calculate overall standard deviation: Check to estimate the overall standard deviation using unbiasing constants. The default is to not use the unbiasing constants.
