Tolerance Intervals - Storage
Stat > Quality Tools > Tolerance Intervals > Storage
You can store the tolerance bounds for the normal and nonparametric methods in the worksheet. You can also store the tolerance factors for the normal method. Minitab uses an exact method to calculate the tolerance factors (see [6, 8, 9]).
See Normal and nonparametric methods for tolerance intervals for more details.
Normal method tolerance bounds: Check to store the normal method tolerance bounds.
Nonparametric method tolerance bounds: Check to store the nonparametric method tolerance bounds.
Tolerance factors: Check to store the exact tolerance factors, also called k factors, for the normal method.
