Stat > Quality Tools > Multi-Vari Chart > Options
Allows you to choose output display options.
Display options
Display individual data points: Check to draw individual data points on the chart
Connect means for Factor 1: Check to connect the factor level 1 means with a line.
Connect means for Factor 2: Check to connect the factor level 2 means with a line.
Connect means for Factor 3: Check to connect the factor level 3 means with a line.
Title: Type the desired text to replace the default title with your own custom title.
