Pareto Chart - Options
Stat > Quality Tools > Pareto Chart > Options
Allows you to specify the x and y axis labels, not display the cumulative percent, and type your own custom title.
X axis label: Type the x axis label. If you do not specify a label, the default label is "Defect."
Y axis label: Type the y axis label. If you do not specify a label, the default label is "Count."
Do not chart cumulative percent: Check to not show cumulative percent symbols, connecting lines, and percent scale.
Title: Type the desired text to replace the default title with your own custom title.
