To create a G chart, you can record your data in one of the following ways:
When your data are entered as dates, Minitab calculates the number of days between events and plots each value on the G chart. When you use dates, you should verify that the number of possible opportunities per day is fairly constant.
Date of infection |
4/17/11 |
4/24/11 |
4/26/11 |
5/14/11 |
5/16/11 |
You can record either the number of opportunities between events or the number of opportunities until an event occurs.
Suppose infections occurred in the 4th, 16th, 27th, 50th, and 80th patient in an emergency room. If you record the number of patients between events, the data are shown below in the Between column. If you record the number of opportunities until an event, the data are shown below in the Until column.
Between |
Until |
11 |
12 |
10 |
11 |
22 |
23 |
29 |
30 |
If your data are recorded as the number of opportunities until an event, Minitab subtracts 1 from each value to convert the data to number of opportunities between events and plots the converted values on the G chart.
