Options - Limits
main topics
    how to     see also
...  > control chart Options  > Limits
Charts  G, T
Allows you to draw control limits above and below the mean at percentiles of the distribution. You can also set bounds on the upper and/or lower control limits.
Display additional percentile limits at
These percentiles of the distribution: Enter one or more values. The values that you enter are the number of percentiles above and below the center line. If you enter more than one value, a pair of control limits is drawn for each number in the list.
Place bounds on control limits
Lower control limit bound: Check to set a lower bound for the control limits.
Upper control limit bound: Check to set an upper bound for the control limits.
