image\LOGOBIG.gifData
To create a T chart, you can record your data in one of the following ways:
·  Dates and times of events
·  Time between events
·  Number of intervals between events
When your data are entered as dates and times, Minitab calculates the amount of time between events and plots each value on the T chart.
Date and time of patient fall
1/22/2011 8:05AM
1/25/2011 4:30PM
2/3/2011 5:45AM
2/5/2011 11:30AM
2/9/2011 9:30PM
Time between events
Time between events, also known as elapsed time, must be entered in the worksheet as hours, minutes, and seconds (hh:mm:ss format). If you do not record seconds, Minitab reads the seconds as 00. For example, Minitab reads the first value below as 80:25:00.
Time between patient falls
80:25
205:15
53:45
106:00
You can record the number of intervals between events as days or hours. The number of days or hours must be greater than or equal to 0. A value of 0 indicates that two events happened simultaneously.
Number of days between patient falls
3.33
8.5
