Stat > Control Charts > Multivariate charts > Multivariate EWMA > MEWMA Options > Limits
Specifies the confidence limit positions.
Place bounds on confidence limits
Upper confidence limit bound: Check to set the upper confidence limit bound, then type the upper limit (must be greater than 0). If the calculated upper confidence limit is greater than the upper bound, Minitab draws a horizontal line labeled UB at the upper bound instead.
