... > control chart Options > Display
Charts All charts except Z-MR
Use to display the control chart by stage or by number of plotted points and to display the test results in the Session window and the control limits and center line limits for all stages.
Subgroups to display
All: Choose to display all subgroups.
Last: Choose to display a specific number of subgroups, and enter the number of subgroups.
Split chart into series of segments for display purposes
Do not split: Choose not to split the chart.
Number of subgroups in each segment: Choose to split the control chart into segments of a specified number of points, and enter the number of subgroups for each segment.
Each segment corresponds to a stage (if chart has stages): Choose to split the control chart by stage when you have specified stages in control chart Options > Stage.
Other
Display test results in Session window: Check to display the test results in the Session window.
Display control limit / center line labels for all stages: Check to display control limits and center line labels for each stage of your control chart. You can set preferences for labels and other displays of control limits, such as changing color or line type, using Tools > Options > Control Charts and Quality Tools.
