Options - Parameters
main topics
     how to     see also
... > control chart Options > Parameters
Charts   R, S, Moving Range, CUSUM
Enters historical data for estimating s. For example, if you have a known process parameter or an estimate obtained from past data, you may enter this value or values. If you do not specify a value for s, Minitab estimates it from the data. You can omit or include certain subgroups when estimating parameters using Estimate.
Standard deviation: Enter the historical standard deviations as constants.
