1 In the control chart dialog box, click control chart Options. Click the Estimate tab.
2 Under Method for estimating standard deviation, choose a method. Then click OK.
When you use Omit the following subgroups when estimating parameters with Length of moving range, Minitab excludes any moving ranges with omitted data from the calculations. |
