To customize the control limits
1 In
the control chart dialog box, click control
chart Options.
Click the Limits tab.
2 Do any of the following:
· To
specify where control limits are drawn: under Display
additional sigma limits at, enter one or more values in These
multiples of the standard deviation. Each value is the number of
standard deviations the lines should be drawn at, above, and below the
mean.
· To
set bounds on the control limits: check Lower
standard deviation limit bound (and/or Upper
standard deviation limit bound) and enter a value. Each value represents
the number of standard deviations below and above the mean.
3 Click OK
in each dialog box.
