A type of time-weighted control chart that displays the cumulative sums (CUSUMs) of the deviations of each sample value from the target value. Because it is cumulative, even minor drifting in the process mean will lead to steadily increasing (or decreasing) cumulative deviation values. Therefore, this chart is especially useful in detecting processes that are slowly slipping away from the target value due to machine wear, calibration issues, etc. The points on the CUSUM chart should fluctuate randomly around zero. If a trend develops upwards or downwards, it should be considered as evidence that the process mean has shifted, and you should look for special causes.
Minitab generates two kinds of CUSUMs:
For example, a manufacturer of centrifuge rotors wants to track the diameter of all rotors produced during a week. The diameters must be close to the target because even small shifts cause problems. The following CUSUM chart (two one-sided CUSUMs) resulted.
CUSUM Chart |
The points appear to vary randomly around the center line and are within the control limits, with the exception of one point. No trends or patterns are shown. The variability in the rotor diameter appears to be stable, but the out-of-control point should be investigated.
The plot points can be based on either subgroups or individual observations. When data are in subgroups, the mean of all the observations in each subgroup is calculated. CUSUM statistics are then formed from these means. When you have individual observations, CUSUM statistics are formed from the individual observations.
