Many analyses require an assumption of normality. In cases when your data are not normal, sometimes you can apply a function to make your data approximately normal so that you can complete your analysis.
For example, suppose you would like to perform a capability analysis on the time required to deliver pizzas. Knowing that there is some minimum time (lower bound), but probably no maximum time (upper bound), your data probably will skew to the right.
Pizza delivery times are right skewed and don't appear normally distributed. |
Take the reciprocal to make the data more normal. The reciprocal is obtained by using the equation of Y = 1/X. So the transformed data = 1 / delivery time. The probability plot shows the transformed data much more closely following a normal distribution. |
Depending on your data, there are many different functions such as square root, logarithm, power, reciprocal or arcsine, that you could apply to transform your data. When you aren't sure which transformation to try, Minitab can help.
Minitab provides two methods for transforming your data:
The Box-Cox transformation is easy to understand, but is very limited and often does not find a suitable transformation. It is also only available for data that are positive.
If the Box-Cox algorithm does not find a suitable transformation, then try the Johnson transformation (or assume that your data follows a non-normal distribution and use another distribution instead of transforming the data). The Johnson transformation function is more complicated, but is very powerful for finding an appropriate transformation.
The Box-Cox transformation utilizes the fact that the data are in subgroups (when subgroups > 1); the Johnson transformation does not. That's why the "within subgroup" analysis is only available using the Box-Cox transformation. |
