Customers expect products and services to meet their specifications. When they don't, a defect or defective is present.
For example, a candle's wick should be long enough to light; a waiter should greet his table within 3 minutes of seating.
A defective unit will contain 1 or more defects. New cars may have several defects, some of which may not even be noticed by the customer, but if the car contains a measured and reported defect, the car (or part of the car) may be considered defective.
Consider the loan application process. In this case, the processing department is the customer. You want to know how many defects they see. Your form has 36 entries. You sample 50 forms to estimate the defect rate. One application has 7 incorrect entries - there are 7 defects present on this form. Another application has 4 incorrect entries - there are 4 defects present on this form. Overall, 18 forms have at least one defect, so 18 forms are defective out of 50. Also, as we counted 62 total defects per 1800 opportunities (36 opportunities per form * 50 forms).
"Nonconformity" can be used instead of defect and "nonconforming" can be used instead of defective. |
