A graphical summary of the distribution of a sample that shows its central tendency and variability. The default interval plot display consists of a mean symbol with a 95% confidence interval bar.
Interval plots are especially useful for comparing groups. For example, the following plot compares the breaking strength of steel rod samples produced by four different methods.
While the means appear to be different, the difference is probably not significant because all the interval bars easily overlap. |
Here the difference between means probably is significant because the interval bars do not overlap. |
Variability can be represented in an interval plot by two types of bars:
