Measures of overall process capability, calculated with overall process standard deviation. They measure the distance between the process average and the specification limits, compared to the process spread:
If Ppk, PPU, and PPL are equal, the process is centered at the exact midpoint of the specification limits. Compare your values to benchmarks to determine whether to improve your process; many industries use benchmark values of 1.33. The graphs below illustrate various situations:
Ppk = PPL = PPU = 2.65 |
This graph shows an ideal case. The value of all three indices is 2.65, which indicates that the distance between the process average and the each specification limit is 2.65 times the one-sided process spread. |
Ppk = min {PPL = 0.92, PPU = 4.37} = 0.92 |
When PPL < PPU, the process is not centered. It is more likely to produce defective units that violate the lower specification limit. |
Ppk = min {PPL=4.37, PPU = 0.92} = 0.92 |
When PPL > PPU, the process is not centered. It is more likely to produce defective units that violate the upper specification limit. |
A disadvantage of the Ppk index is that it only represents one side of the process curve, and tells you nothing about the other extreme. For example, the two graphs below display processes with identical Ppk values. However, one violates both specification limits, and the other only violates the lower specification limit. To avoid mistakes, consider all indices along with a graphical summary to draw meaningful conclusions.
Ppk = PPL = PPU = 0.92 |
Note: |
These capability indices are analogous to Cpk, CPL, and CPU, which assess the same properties using information from subgroups. |
