The use of statistical techniques to analyze a process in order to monitor, control, and improve it. The objective is to have a stable, consistent process that produces the fewest defects possible. Minitab has several SPC tools, including :
The central idea of SPC is to control variation so as to avoid product defects. There are two kinds of variation in any process: common causes and special causes. Common causes refer to occurrences that contribute to the natural variation in any process. Special causes are unusual occurrences that are not normally (or intentionally) part of the process. While some degree of common cause variation will naturally occur in any process, it's important to identify and attempt to eliminate special causes of variation.
For example, you work for a company that makes ball bearings, and you would like reduce the number of defects. Using quality tools such as pareto charts and cause & effect diagrams you have determined that ball bearing roughness is your highest defect rate. Before you begin to look for ways of improving your process, you have to determine whether the process is stable; that is, whether only common cause variation is present. You test five samples every hour for two days and then produce an xbar control chart.
There are two points that are outside the control limits. You need to find out why this has happened and eliminate the cause of this variation. Once you have done this, you can continue to use statistical process control tools to improve the process and then to monitor the process after improvements have been made. |
