Nelson tests for special causes - each of the tests for special causes, shown below, detects a specific pattern in the data plotted on the chart. The occurrence of a pattern suggests a special cause for the variation, one that should be investigated.
For example, suppose you monitor the level in your cooling tanks with control charts. You see that the 7th plotted point fails test 1 by exceeding the control limits. You should investigate your process to determine what happened during this time.
Test 1 1 point more than 3s from center line |
Test 2 9 points in a row on same side of center line |
Test 3 Six points in a row, all increasing or all decreasing |
Test 4 Fourteen points in a row, alternating up and down |
Test 5 2 out of 3 points > 2s from center line (same side) |
Test 6 4 out of 5 points > 1s from center line (same side) |
Test 7 15 points in a row within 1s of center line (either side) |
Test 8 8 points in a row > 1s from center line (either side) |
The Western Electric decision rules are also commonly used to test for special causes.
The following variables charts can detect all eight tests: X and R, X and S, X, Individuals, I-MR-R/S, I-MR, T, Capability Sixpack (Normal), and Capability Sixpack (Between/Within). The R, S, Moving Range, and G Charts, as well as the attribute control charts, can detect the first four tests. |
