Analyze Factorial Design - Results (2-level factorial design, 2-level split-plot design)
Stat > DOE > Factorial > Analyze Factorial Design > Results
Control the level of detail in the display of output to the Session window.
Display of results: Choose the level of detail to display.
Simple tables: Choose to display the simpler versions of all tables.
Expanded tables: Choose to display the expanded versions of the ANOVA, Coefficients, Model summary, and Fits and Diagnostics tables.
Method: Check to display a table that summarizes non-default settings.
Analysis of variance: Check to display the ANOVA table that includes the sums of squares by source and the p-values.
Model summary: Check to display statistics that evaluate model fit, including R2.
Coefficients: Check to display the coefficients, effects, and p-values. The drop-down list allows you to control how many coefficients for the terms are in the table.
Default coefficients: Choose to display all linearly independent coefficients for the terms.
Full set of coefficients: Choose to display coefficients for all levels of the terms, which includes the final, linearly dependent, level.
Regression equation: Check to display the regression equation(s).
Alias structure: Allows you to specify how to display the alias table.
Display default interactions: Choose to display the default interactions. All interactions are displayed for 2 to 6 factors, up to three-way interactions for 7 to 10 factors, and 2-way interactions for more than 10 factors. If the design is not orthogonal and there is partial confounding, Minitab will not print alias information.
Display interactions up through order: Choose to specify the highest order interaction to display in the alias table, then choose the order from the drop-down list. Be careful! A specification larger than the default could take a very long time to compute.
Fits and diagnostics: Check to display fits and diagnostics.
Only for unusual observations: Choose to display fits and diagnostics for only the unusual observations.
For all observations: Choose to display fits and diagnostics for all observations.
Means: Check to display the least squares means that you specified in the Options dialog.
