Stat > DOE > Factorial > Analyze Factorial Design > Terms
Specifies which terms to include in the model.
Include terms in the model up through order: Use this drop-down list to quickly set up a model with a specified order. Choose the maximum order for terms to include in the model. For example, if you choose 2,
Available Terms: Shows all terms that are estimable but not included in the fitted model.
Selected Terms: Minitab includes terms shown in Selected Terms when it fits the model.
Cross: Use this to cross two or more terms that you select in Available Terms. Suppose you select A, B, C. When you click Cross, Minitab adds A*B*C. This option is active only when the cross of the terms that you select produces an estimable term.
Default: Populates the model with all main effects and interaction effects that are estimable.
Include blocks in the model: Check to include blocks in the model. Minitab only enables this checkbox if you specified more than one block in the Create or Define Factorial Design dialog box.
