Analyze Variability - Options
Stat > DOE > Factorial > Analyze Variability > Options
Use to:
·    Choose between least squares regression and maximum likelihood regression
·    Specify the confidence level and type of confidence interval
·    Display the least squares means for main effects and interaction effects in the Session window
Estimation method
Least squares regression: Choose to analyze the standard deviations using least squares regression.
Maximum likelihood: Choose to analyze the standard deviations using maximum likelihood estimation.
Confidence level for all intervals: Enter the confidence level. The default is 95.
Type of confidence interval: Choose the type of confidence interval: two-sided (default), lower bound, or upper bound.
Means table: Use this drop-down list to quickly display means for groups of terms. If an expected term does not appear in either list, add it to the model. You can choose one of these options:
None
Main effects
Two-way interactions
All terms in the model
Specified terms
For more information on these options, see Displaying Means for Model Terms.
If you choose Display means for specific terms, use the arrow keys to move terms from one list to the other. Select one or more terms in one of the lists, then click an arrow key. The double arrows move all the terms in one list to the other. You can also move a term by double-clicking it.
Available Terms: Shows all terms that you can display means for.
Selected Terms: Minitab displays the means for the terms shown in Selected Terms when it fits the model.
