Stat > DOE > Factorial > Create Factorial Design > choose General full factorial design > Design
Allows you to name factors, specify the number of levels for each factor, add replicates, and block the design.
Factor: Shows the number of factors you have chosen for your design. This column does not take any input.
Name: Enter text to change the name of the factors. By default, Minitab names the factors alphabetically.
Number of Levels: Enter a number from 2 to 100 for each factor. Use the arrow keys to move up or down the column.
Number of replicates: Enter a number up to 50. Suppose you are creating a design with 3 factors and 12 runs, and you specify 2 replicates. Each of the 12 runs will be repeated for a total of 24 runs in the experiment.
Block on replicates: Check to block the design on replicates. Each set of replicate points will be placed in a separate block.
