1 Choose Stat > DOE > Modify Design.
2 Choose Randomize design and click Specify.
3 Do one of the following:
4 If you like, in Base for random data generator, enter a number.
5 Click OK.
You can use Stat > DOE > Display Design to switch back and forth between a random and standard order display in the worksheet. |
