1 Choose Stats > DOE > Preprocess Responses for Analyze Variability.
2 Do one of the following:
1 Choose Compute for repeat responses across rows.
2 In Repeat responses across rows of, enter the columns containing repeat response measurements.
3 In Store standard deviations in, enter the storage column for the standard deviations.
4 In Store number of repeats in, enter the storage column for the number of repeats.
5 In Store means in (optional), enter the storage column for the means of the repeats.
1 Choose Compute for replicates in each response column. Under Replicates in individual response columns, complete the table as follows:
2 Under Response, enter a column containing replicate responses in the first row.
3 Under Store Std Dev in, enter the storage column for the standard deviations for the response in the first row.
4 Under Store number of replicates in, enter the storage column for the number of replicates for the response in the first row.
5 In Adjust for covariates, enter columns containing covariates for which you want to account in the standard deviations for replicates. Minitab uses the same set of covariates for each response.
6 If you have more than one response with replicates, repeat steps 1-4 for each response in the next available row.
1 Choose Standard deviations already in worksheet. Under Precalculated standard deviations in worksheet, complete the table as follows:
2 Under Store Std Dev in, enter the column containing the standard deviations of your repeat or replicate response in the first row.
3 Under Number of repeats or replicates, enter the column or constant containing the number of repeats or replicates in the first row.
4 If you have more than one column with stored standard deviations, repeat steps 2 and 3 for each stored column in the next available row.
3 Click OK.
