Stat > DOE > Mixture > Contour/Surface Plots > check Contour plot > Setup > Options
Allows you to define the background grid and determine the title of your plot.
Grid Lines
At intervals: Choose to define the background grid, and then choose an interval from the list.
None: Choose to suppress the display of the background grid.
Title: To replace the default title with your own custom title, type the desired text in this box.
