Stat > DOE > Mixture > Contour/Surface Plots
You can use Contour/Surface Plots to display two types of response surface plots: contour plots and surface plots. These plots show how a response variable relates to three components based on a model equation.
Contour plot: Check to display a contour plot, then click <Setup>.
Surface plot: Check to display a surface plot, then click <Setup>.
