Stat > DOE > Mixture > Contour/Surface Plots > check Surface plot > Setup
Allows you to display components, process variables, and an amount variable on a surface plot.
Response: Choose a response for the plot.
Components or Process Variables
Select a triplet of components for a single plot: Choose to plot three components.
X-Axis: Choose a component to display on the x-axis.
Y-Axis: Choose a component to display on the y-axis.
Z-Axis: Choose a component to display on the z-axis.
Generate plots for all triplets of components: Choose to generate plots for all triplets of components, each in a separate window.
Select a pair of numeric process variables for a single plot: Choose to generate a surface plot for one pair of process variables.
X-Axis: Choose a process variable to display on the x-axis.
Y-Axis: Choose a process variable to display on the y-axis.
Generate plots for all pairs of numeric process variables: Choose to generate surface plots for all combinations of process variable levels.
Model Fitted in
Proportions: Choose to refit the model in proportions.
Pseudocomponents: Choose to refit the model in
Component Unit in Plot(s)
Amount: Choose to display the components in amounts.
Proportion: Choose to display the components in proportions.
Pseudocomponent: Choose to display the components in pseudocomponents.
