Stat > DOE > Mixture > Contour/Surface Plots > check Contour plot or Surface plot > Setup > Settings
You can set the holding level for components, and process variables that are not in the plot at their highest or lowest settings, or you can set specific levels to hold each. The hold values must be expressed in the following units:
If you have text process variables in your design, you can only set their holding values at one of the text levels. |
Hold components at
Lower bound setting: Choose to set all components that are not in the graph at their lower bound.
Upper bound setting: Choose to set all components that are not in the graph at their upper bound.
Component: Shows all the components in your design. This column does not take any input.
Name: Shows all the names of components in your design. This column does not take any input.
Setting: Enter a value to hold each component that is not being plotted. Use the up and down arrows to move in the Setting column.
Hold process variables at
Low setting: Choose to set variables that are not in the plot at their lowest setting.
High setting: Choose to set variables that are not in the plot at their highest setting.
Process Var.: Shows all the process variables in your design. This column does not take any input.
Name: Shows all the names of process variables in your design. This column does not take any input.
Setting: Enter a value to hold each process variable that is not being plotted. Use the up and down arrows to move in the Setting column.
Hold mixture amount at: Choose a total at which to hold the mixture amount.
