Contour/Surface Plots - Contour
Stat > DOE > Mixture > Contour/Surface Plots > check Contour plot > Setup
Allows you to display components, process variables, and an amount variable on a contour plot.
Response: Choose a response for the plot.
Components or Process Variables
Select a triplet of components for a single plot: Choose to plot three components.
X-Axis: Choose a component to display on the x-axis.
Y-Axis: Choose a component to display on the y-axis.
Z-Axis: Choose a component to display on the z-axis.
Select four components for a matrix: Choose to display four simplex design plots in a single page layout. Then choose four components from the drop-down list.
Generate plots for all triplets of components: Choose to generate plots for all triplets of components.
In separate panels of the same page: Choose to display all plots on one page.
On separate pages: Choose to display each plot on a separate page.
Select a pair of numeric process variables for a single plot: Choose to generate a contour plot for one pair of process variables.
X-Axis: Choose a process variable to display on the x-axis.
Y-Axis: Choose a process variable to display on the y-axis.
Generate plots for all pairs of numeric process variables: Choose to generate contour plots for all combinations of process variable levels.
Model Fitted in
Proportions: Choose to refit the model in proportions.
Pseudocomponents: Choose to refit the model in
Component Unit in Plot(s)
Amount: Choose to display the components in amounts.
Proportion: Choose to display the components in proportions.
Pseudocomponent: Choose to display the components in pseudocomponents.
Plot all level combinations: Choose to display single contour and include all the levels of the process variables in a single layout.
Plot all mixture amounts: Choose to display a single contour plot and include all the levels of the amount variable in a single layout.
<Contours>
<Settings>
<Options>
