Stat > DOE > Mixture > Create Mixture Design > Options
Allows you to
Randomize runs: Check to randomize the runs in the data matrix. If you specify blocks, randomization is done separately within each block and then the blocks are randomized.
Base for random data generator: Enter a base for the random data generator. By entering a base for the random data generator, you can control the randomization so that you obtain the same pattern every time.
If you use the same base on different computer platforms or with different versions of Minitab, you may not get the same random number sequence. |
Store design in worksheet: Check to store the design in the worksheet. If you want to analyze a design, you must store it in the worksheet.
Store design parameters in worksheet: Check to store the design parameters (totals, upper and lower bounds of the components, and linear constraints) in separate columns in the worksheet.
