Stat > DOE > Mixture > Create Mixture Design > Process Vars
You can perform a mixture-process variable experiment by including up to seven process variables (factors) in your design. You can also:
Process Variables
None: Choose if you do not want to add any process variables to your design.
Number: Choose to add process variables, then choose the number of variables from the list.
Type of design: Choose the type of design (full or fractional factorial) for the process variables. The available designs depends on the number of process variables.
Fraction number: If you choose a fractional factorial design, you can select the fraction you want to use. By default, Minitab uses the principal fraction.
Process Variable
Name: Enter text to change the name of the process variables. By default, Minitab names the process variables as X1,... ,Xn, where n is the number of process variables.
Type: Choose to specify whether the process variables are numeric or text.
Low: Enter the value for the low setting of each process variable. By default, Minitab sets the low level of all process variables to -1. Process variable settings can be changed to any numeric or text value. If one of the settings for a process variable is text, Minitab interprets the other setting as text.
High: Enter the value for the high setting of each process variable. By default, Minitab sets the high level of all process variables to +1. Process variable settings can be changed to any numeric or text value. If one of the settings for a process variable is text, Minitab interprets the other setting as text.
