Stat > DOE > Mixture > Create Mixture Design
You can create simplex centroid, simplex lattice, or extreme vertices designs.
To create a design from data that you already have in the worksheet, see Define Custom Mixture Design. |
Type of Design
Simplex centroid (2 to 10 components): Choose to generate a simple centroid design.
Simplex lattice (2 to 20 components): Choose to generate a simplex lattice design.
Extreme vertices (2 to 10 components): Choose to generate an extreme vertices design.
Number of components: Choose the number of components in the design to be generated.
