Stat > DOE > Mixture > Create Mixture Design > Results
Control the display of Session window results.
None: Choose to suppress display of results. Minitab stores all requested items.
Summary table: Choose to display a summary of the design. Minitab displays the number of components, design points, process variables, design degree, and mixture total.
Detailed description: In addition to above, Minitab displays the number of boundaries for each dimension, the number of design points for each type, and the bounds of mixture components.
Detailed description and design table: In addition to above, Minitab displays a table with the components and process variables and their settings and the point type at each run.
