Modify Design
overview
    how to     see also
Stat > DOE > Modify Design
After creating a design and storing it in the worksheet, you can use Modify Design to make the following modifications:
·    rename the components
·    rename process variables and change levels
·    replicate the design
·    randomize the design
·    renumber the design
By default, Minitab will replace the current design with the modified design in the worksheet. To store the modified design in a new worksheet, check Put modified design in a new worksheet.
Modification
Modify variables: Choose to rename components, rename process variables, or change process variable level, then click <Specify>.
Replicate design: Choose to add up to ten replicates, and then click <Specify>.
Randomize design: Choose to randomize the design, and then click <Specify>.
Renumber design: Choose to renumber the design.
Put modified design in a new worksheet: Check to have Minitab place the modified design in a new worksheet rather than overwriting the current worksheet.
