Data - Response Optimizer - Mixture Design
Before you use Minitab's Response Optimizer, you must
1    Create and store a design using Create Mixture Design or create a design from data that you already have in the worksheet with Define Custom Mixture Design.
2    Enter up to 25 numeric response columns in the worksheet.
3    Fit a model for each response Analyze Mixture Design.
You can fit a model with different design variables for each response. If an input variable was not included in the model for a particular response, the optimization plot for that response-input variable combination will be blank.
Minitab automatically omits missing data from the calculations. If you optimize more than one response and there are missing data, Minitab excludes the row with missing data from calculations for all of the responses.
