Stat > DOE > Mixture > Response Optimizer > Options
Allows you to define a starting point for the search algorithm, suppress display of the optimization plot, and store the composite desirability values.
Components in design: Displays all the components that have been included in the fitted model. This column does not take any input.
Starting value: To define a starting point for the search algorithm, enter a value for each component. Each value must be between the minimum and maximum levels for that component.
Process variables in design: Displays all the process variables that have been included in the fitted model. This column does not take any input.
Starting value: To define a starting point for the search algorithm, enter a value for each process variable. Each value must be between the minimum and maximum levels for that process variable.
Optimization plot: Uncheck to suppress display of the optimization plot. The default is to display the plot.
Store composite desirability values: Check to store the composite desirability values.
Display local solutions: Check to display the local solutions.
