Once you have created an optimization plot, you can change the input variable settings. Move the red vertical bars to change the factor settings and see how the individual desirabilities and the composite desirability change. For factorial and response surface designs, you can adjust the factor levels. For mixture designs, you can adjust component, process variable, and amount variable settings. You might want to change these input variable settings on the optimization plot for many reasons, including:
When you change an input variable to a new level, the graphs are redrawn and the predicted responses and desirabilities are recalculated. If you discover a setting combination that has a composite desirability higher than the initial optimal setting, Minitab replaces the initial optimal setting with the new optimal setting. You will then have the option of adding the previous optimal setting to the saved settings list.
If you save the optimization plot and then reopen it in Minitab without opening the project file, you will not be able to drag the red vertical bars with your mouse to change the factor settings. |
With Minitab's interactive Optimization Plot you can:
