1 Change input variable settings in the optimization plot by:
You can return to the initial or optimal settings at
any time by clicking |
For factorial designs with center points in the model: If you move one factor to the center on the optimization plot, then all factors will move to the center. If you move one factor away from the center, then all factors move with it, away from the center. |
For a mixture design, you cannot change a component setting independently of the other component settings. If you want one or more components to stay at their current settings, you need to lock them. See To lock components (mixture designs only). |
