Blocking a Box-Behnken Design
When the number of runs
is too large to be completed under steady state conditions, you need to
be concerned with the error that may be introduced into the experiment.
Running an experiment in blocks
allows you to separately and independently estimate the block effects
(or different experimental conditions) from the factor effects. For example,
blocks might be days, suppliers, batches of raw material, machine operators,
or manufacturing shift.
For a Box-Behnken design, the number of ways to block a design depends
on the number of factors. All of the blocked designs have orthogonal blocks.
When you are creating a design, Minitab displays the appropriate choices.
A design with:
· Three
factors cannot be blocked
· Four
factors can be run in three blocks
· Five,
six, seven, or ten factors can be run in two blocks
· Nine
factors can be run in five or ten blocks
If you add replicates
to your design, you can also block on replicates. How this works depends
on whether you have blocks in your design.
· If
your design does not have blocks, Minitab places each set of replicates
in separate blocks.
· If
your design includes blocks, Minitab replicates the existing blocking
scheme. The points in each existing block are replicated to form new blocks.
The number of blocks in your design will equal the number of original
blocks multiplied by the number of replicates. The number of runs in each
block stays the same.
· If
your design includes blocks but you do not block on replicates, Minitab
replicates the points within each block. The total number of runs in the
each block equals the number of original runs times the number of replicates.
The total number of blocks in the design stays the same.
