Stat > DOE > Response Surface > Define Custom Response Surface Design > Designs
Allows you to specify which columns contain the standard order, run order, point type, and blocks.
Standard Order Column
Order of the data: Choose if the standard order is the same as the order of the data in the worksheet.
Specify by column: Choose if the standard order of the data is stored in a separate column, then enter the column.
Run Order Column
Order of the data: Choose if the run order is the same as the order of the data in the worksheet.
Specify by column: Choose if the run order of the data is stored in a separate column, then enter the column.
Point Type Column
Unknown: Choose if the type of design points is unknown.
Specify by column: Choose if your design contains point types, then enter the column containing the point type identifiers.
Blocks
No blocks: Choose if your design is not blocked.
Specify by column: Choose if your design is blocked, then enter the column containing the blocks.
