Stat > DOE > Taguchi > Create Taguchi Design > Designs
Allows you to select a Taguchi design. The designs available depend on your choices in DOE > Taguchi > Create Taguchi Design. You can also choose to add a signal factor to create a dynamic response experiment.
Add a signal factor for dynamic characteristics: Check to add a signal factor to the Taguchi design to create a dynamic response experiment. A dynamic response experiment is used to improve the functional relationship between an input signal and an output response.
