Note When you add a signal factor while creating a new Taguchi design using Stat > DOE > Taguchi > Create Taguchi Design, the run order will be different from the order that results from adding a signal factor using Stat > DOE > Modify Design > Taguchi. The order of the rows does not affect the Taguchi analysis.
1 Choose Stat > DOE > Taguchi > Create Taguchi Design > Designs.
2 Check Add a signal factor for dynamic characteristics. Click OK.
3 In the Create Taguchi Design dialog box, click Factors.
4 If you like, in the signal factor table under Name, click in the first row and type the name of the signal factor.
5 Under Level Values, click in the signal factor row and enter numeric values. You must enter at least two distinct values. Click OK.
You can also specify signal factor levels using a range and increments. You can specify a range by typing two numbers separated by a colon. For example, 1:5 displays the numbers 1, 2, 3, 4, and 5. You can specify an increment by typing a slash "/" and a number. For example, 1:5/2 displays every other number in a range: 1, 3, and 5. |
