Stat > DOE > Display Design > Taguchi
After you create the design, you can use Display Design to change the way the design points are stored in the worksheet. You can display the factor levels in coded or uncoded form.
If you assigned factor levels in Factors subdialog box, the uncoded (actual) factor levels are initially displayed in the worksheet. If you did not assign factor levels (used the default factor levels, which are 1, 2, 3, ...), the coded and uncoded units are the same.
How to display the points in the worksheet
Units for factors:
Coded units: Choose to display the factor levels in the worksheet in coded form.
Uncoded units: Choose to display the factor levels in the worksheet in uncoded form.
