In the Example of a simple histogram, you determine the amount of torque required to remove shampoo bottle caps. You want to fit a normal distribution to the data.
You can also fit a distribution by choosing a With Fit option from the histogram gallery. |
Distribution 1 Open the worksheet CAP.MTW. 2 Choose Graph > Histogram. 3 Choose Simple, then click OK. 4 In Variables, enter Torque. 5 Click Data View. 6 Click the Distribution tab. 7 Check Fit Distribution. 8 Click OK in each dialog box. |
