In the Example of a simple scatterplot, you examine the relationship between voltage remaining in your batteries immediately after a flash and the length of time required for a battery to support another flash. You want to fit a lowess line.
Similar lowess smoother functions are available for matrix plots and time series plots. |
1 Open the worksheet BATTERIES.MTW. 2 Choose Graph > Scatterplot. 3 Choose Simple, then click OK. 4 Under Y variables, enter FlashRecov. Under X variables, enter VoltsAfter. 5 Click Data View. 6 Click the Smoother tab. 7 Under Smoother, choose Lowess. 8 Click OK in each dialog box. |
